Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: JAVA: How to change the default furniture catalog? » » » » Post: Re: JAVA: How to change the default furniture catalog? |
Print at Oct 7, 2026, 3:28:35 AM |
| Posted by Sweeto at Nov 27, 2015, 5:02:56 PM |
Re: JAVA: How to change the default furniture catalog? Hello digitaltrails, thank you for your answer. I have watched this video to understand how to build a project with ant: https://www.youtube.com/watch?v=qOhfl9gayB8 The options for an ant build are in the "build.xml"-file, which is located in this folder: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\ The "build.xml"-file does not contain any command, that will tell ant to copy files to this folder (the default output folder of my eclipse project): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\classes Instead ant copies the files to this folder (the build folder gets deleted at the end of the build process): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\build\classes I could add <copy todir="classes\com\eteks\sweethome3d\io\resources"> Have a nice weekend! Greetings, Sweeto |
Current timezone is GMT Oct 7, 2026, 3:28:35 AM |
