Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Door -2- » » » » Post: Re: Door -2- |
Print at Oct 4, 2026, 6:55:04 AM |
| Posted by JUGGERNAUT at Dec 18, 2015, 6:50:45 AM |
Re: Door -2- THE DOOR AND FRAME ARE ONE OBJECT. IF YOU PLACE A FRAME FIRST, AND THEN A DOOR INTO YOUR FLOOR PLAN, YOU NEED TO GROUP THE TWO OBJECTS TOGETHER.(SELECT BOTH THE OBJECTS, THEN RIGHT CLICK AND SCROLL DOWN UNTIL YOU SEE "GROUP", THEN CLICK. THIS WILL COMBINE BOTH OBJECTS AS ONE.....SIMILAR PRINCIPLE AS IN POWERPOINT). ONLY THEN CAN YOU SIZE IT AS ONE OBJECT, ELSE YOU NEED TO SIZE INDIVIDUALLY. |
Current timezone is GMT Oct 4, 2026, 6:55:04 AM |
