Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: disable ratios lock of lightsource » » » » Post: Re: disable ratios lock of lightsource |
Print at Oct 18, 2026, 6:57:44 PM |
| Posted by Puybaret at Dec 19, 2015, 4:17:14 PM |
Re: disable ratios lock of lightsource The light sources are necessarily a sphere because their lighting effect used in SunFlow renderer is based on a sphere defined by a point + a radius, noting else. Deforming it on Sweet Home 3D side wouldn't change anything once rendered in Sunflow. About colors, I'm not sure about what you mean. If you don't want any influence of the sun color according to the hour of the day. choose a night hour and light the scene only with your own source lights. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 18, 2026, 6:57:44 PM |
