Print at Oct 19, 2026, 2:31:20 AM
Posted by Puybaret at Dec 19, 2015, 4:27:14 PM
Re: Export to OBJ Format
Ouch, it's the first time I read a report about such a big file! There's no theoretical limit, so the problem must come from something else.
Did you try to select one of the object that doesn't work and export only that object to check if Sweet Home 3D is able to handle it correctly?
