Print at Sep 29, 2026, 4:23:21 PM
Posted by digitaltrails at Jan 8, 2016, 4:18:39 AM
Re: Change color plugin
If you look at the screen shot in the original post, there is a very wide "Apply" button along the whole bottom of the panel labelled Replace from color with to color on matching items - I guess it's not obvious its a button. I need to put a bit more work into the interface, but I thought I'd release it now as I'm unsure of how much free time I will have in coming weeks).
I'm not sure why you aren't seeing the Colors in use filled swatches. It could be a paint/refresh issue, or it may be a Java version/platform issue. Perhaps try clicking on the tab twice - I did have a paint/refresh bug, but I thought I had fixed it, before the fix I had to click twice to get the swatches to appear, but what you are seeing is different, so there may be another bug/issue.
A few minutes ago, I installed your plug-in. Although it appears and seems to function, I'm not sure it actually does what you describe.
The tab Colors in use gives small rectangles where the borders have the colours in use (but which are not filled with that colour as in your image).
In the lower half the rectangles are present (without fill) and colours can be changed. However, the colours are not applied to the model(s), and there is no Apply button to execute the changes you make.
Maybe I'm doing something wrong? Maybe the plug-in is a bit too much in beta stage?
I'm using a computer with Windows 10 64 bits and SH3D v5.1 64 bits.
