Print at Oct 2, 2026, 5:44:33 AM
Posted by Dyn69 at Jan 24, 2016, 2:31:37 AM
How to Change The File Size
Hello,
I currently am designing a garden layout in SH3D. With a pond and some rocks, grass, and of course bush and flowers.
The problem is... my garden is "running" slowly. You see, as i imported and put so many bushes and grass inside, it became one large file. More than 310.000 KB in size. And so the loading is taking - likely- forever TT^TT
Is there any possible way to make/change the file to a smaller size (not the dimension but the kb size) ?
(like -for example- when you use photoshop, you can merge the layers or resize the resolution to decrease the size)
I am fine with merging the bush, flowers, and grass as one layer (1 small file) if there is a way to it.
Or maybe there is another way to solve the problem? I'm fine with whatever it is as long as my file is not as big as it is right now :'(
Fyi, i've tried to convert the rocks and flowers to obj file, but it's still too big, 240.000 kb in size TT^TT
Thank you in advance :)
