Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Splash Screen (Not Responding) » » » » Post: Re: Splash Screen (Not Responding) |
Print at Oct 2, 2026, 10:55:24 AM |
| Posted by Puybaret at Jan 28, 2016, 8:58:48 AM |
Re: Splash Screen (Not Responding) Maybe you could try with the 32 bit version of the program. Sometimes, the 32 bit version of video drivers works better. You won't be able to design houses with many detailed objects because of memory limitations, but if you want to try, install a JRE 32 bit (installer noted x86), then click on this link to launch it with Java Web Start (the About dialog of Sweet Home 3D will tell you if you actually run the program in 32 bit or 64 bit). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 10:55:24 AM |
