Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Visibilité du toit / hidden roof » » » » Post: Re: Visibilité du toit / hidden roof |
Print at Sep 26, 2026, 9:58:07 PM |
| Posted by Puybaret at Feb 10, 2016, 5:57:05 PM |
Re: Visibilité du toit / hidden roof It looks like the triangles that you use are single sided and the visible side is oriented towards the ground. When you import them, you should select the option Invert back and front faces at the second step of Furniture import wizard. You could also use some double sided triangles or simply use this simple triangle that you'll resize. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 9:58:07 PM |
