Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Toggle visibility INSIDE grouped items » » » » Post: Re: Toggle visibility INSIDE grouped items |
Print at Sep 30, 2026, 7:52:37 AM |
| Posted by Puybaret at Feb 12, 2016, 2:13:15 PM |
Re: Toggle visibility INSIDE grouped items The bounding box of an individual piece is used to select it, and the bounding box of pieces and groups is used to place objects along walls that depends on magnetism when it's active, and in other things like alignment menu items. Maybe I could display invisible objects of a visible group with a surrounding box drawn with a very light gray? I'm going to see how it could look like. And there are other things to consider: if you make all objects of a group invisible, should this group be automatically considered as invisible in the furniture list too (keep in mind that the group may be collapsed in the list)? When you toggle the visibility of a group itself, should it change the visibility of all its child objects too? It's not a so easy subject! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 7:52:37 AM |
