Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Mass importing object/textures » » » » Post: Re: Mass importing object/textures |
Print at Oct 4, 2026, 3:42:39 PM |
| Posted by okh at Feb 12, 2016, 3:44:15 PM |
Re: Mass importing object/textures Whether it is a good idea, I suppose, depends on your definition of a ton. But yes, you can import several. If you drag-drop multiple items into SH3D, they should import one by one. But that will involve some clicking accepting the properties. Better idea is to use existing libraries on the 3d models page for the existing collections. Or in the case of models with other origin, try Furniture Library Editor and Texture Library editor (both available from the download page, other downloads). The library editors are much better suited for multiple downloads, at least if the relative dimensions are correct and do not need editing. You can also edit multiple items and their properties at the same time inside the editors - e.g. setting several textures to the same scale. ok |
Current timezone is GMT Oct 4, 2026, 3:42:39 PM |
