Print at Oct 5, 2026, 10:31:53 PM
Posted by Ceciliabr at Feb 17, 2016, 4:31:45 PM
Re: What am I doing wrong?
I make most of my models from scratch.
The downlights are real simple, tree elements: An open cylinder with a ring around the bottom and a closed cylinder to seal the top ( to prevent the light from hitting the ceiling). Export it as an obj-file, and import it using the import furniture option. If you tick the "Staircase"-box, you can elevate them into the ceiling. You have to place a light-source in it afterwards, since obj-files don't support lights. In use the incandescent light and scale it to 2cm. The higher you put the, the more focused the light beam becomes... obviously.
