Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Landscaping » » » » Post: Re: Landscaping |
Print at Sep 27, 2026, 8:16:59 PM |
| Posted by okh at Feb 18, 2016, 5:47:06 PM |
Re: Landscaping Well - there is sort of a disclaimer saying that SH3D is not really landscaping software. So do not expect it to happen automatically... That said, it is possible to create a landscape around your creation. Exactly how, depends on whether you need a basement or not. It seems you are in an explorer phase - in which case you may not need to read on. If you are not going to have a basement (negative elevation on the lowest levels), you can just use a triangle (or some other shape) for your terrain (giant triangle). But a triangle will be visible in the lower levels, so if you need a basement, you need to put your triangles (or other shapes) AROUND the foundation to simulate the terrain. Here is a, maybe not very elegant (but relatively simple), way of doing it: template_scandinavian.sh3d. Note that you may want to play with levels (and in-between levels) in addition to some shapes (SF models 299 ) around the house. ok |
Current timezone is GMT Sep 27, 2026, 8:16:59 PM |
