Print at Sep 25, 2026, 10:24:59 AM
Posted by okh at Feb 20, 2016, 2:53:54 PM
Re: How to make a horizontal tube
How can I make this cylinder hollow?
Well, it is hollow already... but if you want to open the ends you can set top and bottom to invisible (requires newest 5.2) - but as the inside has not texture - it may not give the effect you want.
Which means you are probably better off trying the cylinder shared by Ceciliabr in thread 6462 - that should be open ended.
