Print at Sep 25, 2026, 10:27:29 PM
Posted by Ceciliabr at Feb 25, 2016, 7:02:15 PM
Re: high quality pictures at night - outside
@okh
You are right. Using separate levels is a time-saver and a cure for o lot of frustrations.
I'm using levels a lot, almost like layers in Photoshop, and with the option to control visibility, it works perfectly.
One thing should be said about levels, though, that when you copy with cmd-left-click, it is copied to the level you are working on, like if you are using cmd-c & cmd-v.
And if the object is huge - like f.i. a terrain – ctrl-x hangs the machine for several minutes.
Why would I use ctrl-x?
To move it to the right level, because I have tweaked the copied element so much (on the wrong level), that don't want to lose my work.
Just mentioning it...
