Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Has the renderingprosess been altered i 5.2? » » » » Post: Re: Has the renderingprosess been altered i 5.2? |
Print at Sep 29, 2026, 8:01:04 PM |
| Posted by mazoola at Feb 26, 2016, 12:14:54 PM |
Re: Has the renderingprosess been altered i 5.2? You've probably already done this, but if not, make sure your camera (depth-of-field) and Virtual Visitor (angle of vision) settings are at the default. I've not poked around to see what defaults Emmanuel uses in rendering the 3D view window, but I'd assume a mismatch between them and the ones used to create the final 'photo' render might cause the apparent anomaly you demonstrate. |
Current timezone is GMT Sep 29, 2026, 8:01:04 PM |
