Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: furniture library copy » » » » Post: Re: furniture library copy |
Print at Sep 26, 2026, 9:10:42 AM |
| Posted by mazoola at Mar 5, 2016, 3:59:02 AM |
Re: furniture library copy Sorry to have missed your question earlier. Typically, if you update by installing a newer version without removing the older one, your complete furniture libraries will be left unchanged.* If you are moving to a new system or OS, or if you have some other need to uninstall the older version first, you can save all of your non-default furniture models in a Sweet Home 3D furniture library file (a .SH3F file) by using Furniture > Export imported furniture to SH3F. You can then import this library into your updated install of SH3D. If you wish to modify or delete any of the furniture objects from this library prior to import, you can do so using the Sweet Home 3D Furniture Library Editor. |
Current timezone is GMT Sep 26, 2026, 9:10:42 AM |
