Print at Sep 28, 2026, 5:35:16 PM
Posted by maineiac at Mar 5, 2016, 11:13:00 AM
java issues on OS 10.11.3 (El Capitan)
Hi there
I've got java installed but on startup Sweet Home 3D is unable to locate it... /Applications/SweetHome/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
No Java runtime present, requesting install.
logout
this is the java version I've got installed:
java -version
java version "1.8.0_71"
Java(TM) SE Runtime Environment (build 1.8.0_71-b15)
Java HotSpot(TM) 64-Bit Server VM (build 25.71-b15, mixed mode)
Where does Sweet Home 3D try to find java? I'm pretty sure I just have to either adapt some Sweet Home startup script or add an additional java path somewhere...
Any suggestions?
Best regards, Alex
