Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: java issues on OS 10.11.3 (El Capitan) » » » » Post: Re: java issues on OS 10.11.3 (El Capitan) |
Print at Sep 27, 2026, 6:12:47 PM |
| Posted by Puybaret at Mar 6, 2016, 12:44:39 AM |
Re: java issues on OS 10.11.3 (El Capitan) At this time, the installer version requires to install Java 6 to run under El Capitan. Or if you absolutely want to use Java 8, you can run the Java Web Start version of Sweet Home 3D or its executable Jar version (to run these two versions, the first time, you should click on the downloaded file while maintaining the ctrl key pressed, and choose Open in the contextual menu that will appear). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 6:12:47 PM |
