Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Making counter tops » » » » Post: Re: Making counter tops |
Print at Oct 7, 2026, 9:23:41 PM |
| Posted by mazoola at Mar 7, 2016, 11:59:37 PM |
Re: Making counter tops Emmanuel describes making a counter top using just that method (e.g., creating a floor of the right size and shape) in the second comment of this thread; he even provides a demonstration plan to show how it's done. After creating th floor, you export it as an OBJ model and then import it back in as furniture. That thread describes some issues I ran into while using a similar method of creating counter tops: Instead of using a floor, I created a wall of the correct shape and size, exported it, and imported it, rotating the counter to its correct alignment during the import. I had problems getting textures to map as I wished, and the first post in that thread explains in excessive detail the various approaches I tried. I had to jump through such hoops because the counter top was not rectangular. For the two other counter tops in that plan's kitchen, I did as OK suggests and used boxes, scaled accordingly. Hope this helps! |
Current timezone is GMT Oct 7, 2026, 9:23:41 PM |
