Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Making counter tops » » » » Post: Re: Making counter tops |
Print at Oct 4, 2026, 6:17:00 PM |
| Posted by Ceciliabr at Mar 8, 2016, 7:07:41 PM |
Re: Making counter tops @ somuchfun You can elevate a floor simply by creating a new level and elevate it to 86 cm over your kitchen floor. The thickness can be set to 3-4 cm, and you can design and re-design your counter as much as you want without have to go through the export/import-routine every time you want to try a different placement. To get a sink to make hole in the counter, you just group it with an invisible box (staircase), and then you can move it around on your counter as much as you like. cec |
Current timezone is GMT Oct 4, 2026, 6:17:00 PM |
