Print at Oct 7, 2026, 6:47:15 PM
Posted by Ceciliabr at Mar 15, 2016, 5:04:56 PM
Re: Several problem with using Sweet Home 3D
Yes, the zoom function is a bit... well, peculiar, but:
If the object ( your selected object, that is ) disappears from your screen when you zoom in, hitting the up and down arrows once, will make it appear somewhere within your window. The position is not quite predictable, but it's easy to spot.
And for the camera ( when it's lost): touching the preview window will make your camera visible.
If you haven't already found out: Holding the cmd-button, you can zoom inn/out with your mouse.
Holding shift, your walls maintain their horizontal or vertical positions during move.
Magnetism works only on walls and on heights ( if I have got it correctly) and all other snapping is done with the align-tool.
...and when all else fails, you can always consult the manual.
cec
