Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Problems creating a light » » » » Post: Problems creating a light |
Print at Sep 25, 2026, 9:01:45 AM |
| Posted by Finnithnel at Mar 20, 2016, 5:13:28 PM |
Problems creating a light Hi, I'm trying to create a model for the Ikea Knappa lamp : http://www.ikea.com/fr/fr/catalog/products/50070651/ I created a Knappa.sh3f archive containing the file : - PluginFurnitureCatalog.properties (code below) id#1=Knappaand the folder "models" containing 3 files : - knappa.obj (from blender) - knappa.png (rendered with blender) - knappa.mtl (containing code below) newmtl AmpouleMy main problem is that I'm unable to get a good render inside sweethome3d => When I use only 1 light source with 3.0 diameter, the lamp is rendered correctly (with shadows and so on) but the room get nearly no light (light is filtered by the lamp part) => When I "cheat" by adding another light source of 46 diameter (same as lamp size), then the room is correctly lighted, but the render of the lamp is awfull as it receive light from outside I tried using Tf 1.0 to not filter anything, then a low Ni to let the light get through the lamp, but no matter how I change the settings, the only visible result is when the "illum" parameter is changed; and the result differ but is still not good Any expert could help me to solve this ? |
Current timezone is GMT Sep 25, 2026, 9:01:45 AM |
