Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: AdvancedEditingPlugin - Edit room plan dialog blank » » » » Post: Re: AdvancedEditingPlugin - Edit room plan dialog blank |
Print at Oct 2, 2026, 1:41:22 PM |
| Posted by Shaggy1 at Mar 28, 2016, 10:35:38 AM |
Re: AdvancedEditingPlugin - Edit room plan dialog blank Hi Finally had a chance to have a look at this. I re-visited the initial thread I found and realised it does indeed give the solution to the problem. Clearly I did not read it properly the first time. It seems sweethome3d comes with and uses a local version of jre (for some reason I thought it used the systems version). The plugin does not work with the version sweethome3d comes with (jre1.6.0_45). As mentioned in that thread downloading a later version of jre (I downloaded jre1.8.0_77), installing it in the SweetHome3D-x.y directory and setting jre1.6.0_45 to point to that version fixes the problem. Does anyone know how I can find out where sweehome3d decides where it gets jrel from ? Can this be specified using env variables or is hard coded in the source somewhere ? |
Current timezone is GMT Oct 2, 2026, 1:41:22 PM |
