Print at Sep 23, 2026, 11:50:39 PM
Posted by mazoola at Apr 1, 2016, 7:03:44 AM
Re: VERY slow video rendering
Your other option would be to reduce the resolution and upscale the video during playback. I know you say you're committed to 1920x1080, but you'll likely find, say, a 960x540 frame size perfectly acceptable during playback. (Depending on which codec you use and how you configure it, you might even find a lower resolution video might be of higher fidelity than one with a larger frame size -- they're called 'lossy' formats for a reason!) While you probably won't see a four-fold increase in rendering speed, unless all your furniture is chrome-plated and your walls, floor, and ceiling covered in mirror tiles, you should be able to pump out a 30-second video in a few hours.
