Print at Oct 16, 2026, 5:05:45 AM
Posted by mazoola at Apr 6, 2016, 11:59:10 AM
Re: Is there a mirror model that actually reflects the ojects in the room?
If I remember correctly, you can also create a mirror effect without having to edit object files manually:
- After positioning the item of furniture you wish to have a reflective surface, double-click on it to open the 'Modify furniture' window.
- Under 'Color and texture,' select 'Materials' and click 'Modify.'
- Furniture components you want to be reflective should be assigned a color of pure black (#000000), with the shininess slider set to maximum.
I know I've used this to create 'chrome-plated' fixtures, for instance -and I *think* I've used it to make a mirror. (I'd quickly test it, if I could, but I'm away from home and working on an end-of-life PC that stubbornly refuses to run SH3D.)
I could swear there's a thread here, somewhere, with a comment from Emmanuel explaining this, but I'll be darned if I can find it....
