Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: can i install "sweet Home 3d" on my server? » » » » Post: Re: can i install "sweet Home 3d" on my server? |
Print at Sep 27, 2026, 8:21:30 AM |
| Posted by zerogravity90 at Apr 22, 2016, 11:12:16 AM |
Re: can i install "sweet Home 3d" on my server? You only need a HTTP server like Apache. But you can also use Tomcat, since it handles also requests to static content. First, download source code of the latest version. Then, from the README.TXT file it contains, you'll have to: - download and install last JDK 6, - download and install Ant, - run the following Java command in the directory where you uncompressed the archive of the source code: keytool -genkey -keystore keys.keytool -alias SweetHome3D- run "ant" command in the directory where you uncompressed the archive of the source code. The default javaWebStart target will create signed jars in deploy/lib subdirectory. - edit deploy/SweetHome3D.jnlp file and change the value of the codebase attribute at line 3 to the URL base where you want to host your version of Sweet Home 3D. - upload the content of deploy directory on your server in a directory matching this URL base. Your Java Web Start version of Sweet Home 3D is ready. ![]() Any one can help me? I create keytool to keys.keytool. but when i run command "ant applet" so system required file keys.p12 . How can i do correctly? Thank you! |
Current timezone is GMT Sep 27, 2026, 8:21:30 AM |
