Print at Sep 23, 2026, 1:09:12 PM
Posted by Puybaret at Apr 23, 2016, 8:59:47 PM
Re: Export to HTML5 plug-in
Tonight, the version 1.0.3 fixes a bug in the plug-in that could generate reduced images with a wrong color profile in the exported home. If you saw some issues on the textures of your home while viewing it in a browser (too dark images or mixed with a pink color), then you should export it again with this new version.
Otherwise, this update fixes also an issue on selection management in the Javascript code, but that sould interest you only if you started to use SweetHome3DJS API.
