Print at Sep 30, 2026, 3:06:25 PM
Posted by filmgucker at Apr 25, 2016, 5:01:26 PM
Re: Virtual Reality with Sweethome3d available!
Good news for Galaxy S6 users: The App works with the gear set! But: It'a a bit tricky. First you must deactivate the automatic
start of the gear app so that you can watch vr stuff from other
producers. You will find a howto somewhere in the net.
After having installed the app and export to the phone the way it
is described here you can walk through your Apartment...But:
It is all mirrored :-(...
But: there is another little trick:
Install copytofurniture plugin in sh3d. Mark your whole Project
and make a furniture out of it ;-). Paste it into a new empty Project. Doubleclick on it. Now you can mirror the "furniture".
Export it to obj-File. Now you can have fun with your gear.
However: it doesn't work perfect. It takes very long to load.
It doesnt show everything of a larger projekt. I don't know why.
Too little RAM? Can the developer improve it or fix at least the bug
with the mirroring? Apart from that: This app is realy fantastic!
