Print at Sep 25, 2026, 12:50:22 PM
Posted by Ceciliabr at Jun 20, 2016, 6:31:14 PM
Re: Where the cirle ends and the sky is joined...
@Puybaret
Aha. The advanced editing plugin. Let's try that...
I rotated the whole scene 90ᴼ. Afterwards I placed a 100 X 100 meter (biggest possible, to show the dimensions of the construction) white cross at the new zero point. As you can see, the scene's zero point was shifted from 0, 0 to -6,500, 130 (which makes it quite a job to re-calculate my long list of stored positions).
Now, how does the rotate-function determine the center point, and why should it disregard the original zero point of the matrix, as long as the entire layout is selected? Would it not be both the simplest and the most natural to define the pivot at 0, 0 ?
The reason why this seems important to me, is because I'm planning on making a full quality video-sequence. It will probably take four weeks to render, but I have planned on rendering it while being away on holiday (in Norway). And the image in my last post, is a test rendering (fr.29) of a two second video sequence I have already rendered as a test. It rendered 2 seconds of video ( 50 frames) in 80 hours, and part from the sky, the result was amazingly beautiful. Rendering 20 seconds will probably take like four weeks and produce a 24 GB video file, which I still have room for with 43 GB of memory free when SH3D is running. But, of course, I'm prepared to be disappointed. The computer might fail, and there might be power outlet... or the Bulgarian Mafia might come and steal everything.
But if it works, I will proudly show you the result -:)
BTW:
Cloning and mirroring is basically the same technique.
You end up with matching patterns, which is the only way to make it seamless, and it WILL produce a kaleidoscope-effect. I have struggled with this since I learned it in art school (2002), so I'm not unfamiliar with editing.
The problem occurs when the splice happens in the middle of an important object, as showed in the image. To have a continuing image across the splice, seems to be extremely hard to accomplish. An option to rotate the hemisphere, would make it easier.
cec
