Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Fatal error at starting : need to updated drivers opengl directX » » » » Post: Fatal error at starting : need to updated drivers opengl directX |
Print at Oct 3, 2026, 1:26:57 AM |
| Posted by Trebly at Jul 2, 2016, 4:17:39 PM |
Fatal error at starting : need to updated drivers opengl directXHi, After difficulties to start the application (seems that there are interferences with current Java installation, which ones), everything is OK for starting but I get a failure on "need update of drivers 3D Opengl and DirectX". The issue is traduced by the following error message : "Sweet home 3D must leave because of a fatal error in system 3D. Please update drivers DirectX/OpenGL of your video card" Then I launched an update from nvidia with : 368.39-desktop-win8-win7-winvista-64bit-international-whql.exe (2016) this while the last drivers proposed by Asus are : VGA_nVidia_Win7_64_Z817129616 (2012) But nothing changed : where can be got the updates of the drivers ? for ASUS G73SW (16Go memory) with processor Core I7 2630qm and a graphic card NVidia GTX460M windows 7 pro regularly updated Then I tried a second computer (used for test, much more slower and low memory to check web applications efficiency), it is a HP Pavillon DV7 4163sf (video AMD Radeon 5000 series) - 4Go win 10), same error with best updated driver. I get the same result. On a third ASUS 550C I have been successful. I think that the solution is to have the details af the test which lead to the error : the drivers functions needed (which can be tested with the driver check for directX). May some computers (many) cannot have the needed functions even with directx 11 ? I would know where are the limitations or incompatibility. Best regards Trebly |
Current timezone is GMT Oct 3, 2026, 1:26:57 AM |
