Print at Sep 28, 2026, 9:59:58 AM
Posted by adlerhn at Jul 6, 2016, 11:17:49 AM
SweetHome3D.l4j.ini in Linux
For increasing the max memory, as well as HiDPI adjustments (http://www.sweethome3d.com/support/forum/viewthread_thread,5384_offset,10), Linux users are asked to modify the startup script, which is understandable.
However, this script is part of the installed files, which should not be modified after install, and which will be lost after the next upgrade.
Would it be possible to configure these flags somewhere else, such as in a SweetHome3D.l4j.ini file under ~/.eteks ?
