Print at Oct 18, 2026, 2:59:13 PM
Posted by okh at Jul 12, 2016, 11:13:49 AM
Re: Half landing stairs
@okh: I see you created this nice stairs. Any change to update the model and separate the baluster/handrails in inner and outer ones
I see Puybaret beat me to it and modified the elements to exterior/interior railings. Nice.
However, I also looked at the original model which has eight different textures mapped and there are eleven staircases based on the same template. The tricky thing is to figure out which parts to make customisable without over-complicating the model.
So while the separate inside/outside solution will address one solution, I suspect there are lots of other varieties that may different customisation. In addition to Pubaret's inside/outside solution above, I throw in a couple of other versions that may be useful for different needs.
staircase_180_landing_00_half.zip
staircase_180_landing_00_special.zip
stairs_half.sh3d
