Print at Sep 26, 2026, 2:37:51 AM
Posted by okh at Jul 14, 2016, 7:26:38 AM
Re: Rename furniture?
For items in your plan (lower left pane), you can change names at will (also several at the same time). Select item(s) and change name. As for the catalogue(s) - upper left pane, the easiest is usually to switch between the two different display options (Preferences, Furniture catalog view): categories / search.
You can also use the Furniture Library Editor to change properties to installed libraries/collections. Typically this is used for personal furniture collections.
