Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: High Resolution Output » » » » Post: Re: High Resolution Output |
Print at Oct 18, 2026, 11:52:12 AM |
| Posted by hansmex at Jul 21, 2016, 5:27:20 AM |
Re: High Resolution Output If you need hi-res images, you have to make (render) hi-res images. Example: if you need 300 dpi (dots per inch) resolution for a crisp print, you need to define that resolution. If your printed image is 10x10 inch, you need to define your image as 3000x3000 pixels. Take note that this will cause long rendering times. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 18, 2026, 11:52:12 AM |
