Print at Oct 18, 2026, 4:05:08 AM
Posted by HawkDawg at Jul 23, 2016, 8:40:17 PM
Re: Heights and elevations
I think this will help explain the width of doors and windows.
This is a default door set at 3' wide.
Here's that box set at 3' wide in front of the door.
The width and height includes the frame of the door and/or window.
Does that help?
Increasing floor thickness would add to the bottom of the floor, not the top. Hence adding thickness to a floor will not raise furniture sitting on it, nor will it raise the walls.
The point of setting the thickness of a floor would become apparent when you create a second level/story or a level set at sub-level, like a basement.
You would have to allow for the thickness of the floor when creating other levels.
I guess my previous door dimensions should have read 3' width, 11 5/8" depth, and 7' height.
There is no length.
Hawk
