Print at Oct 4, 2026, 3:25:14 PM
Posted by UKenGB at Jul 27, 2016, 9:52:47 AM
Re: Some (more) thoughts
Background Image
I would like to be able to simply manipulate the background image while looking at the Plan view. I may have to import an image and line it up with what I have already drawn. But if you get it slightly wrong, it's back to the beginning again. I'd like to be able to 'nudge' the image to slightly change its placement and also have some way to finely adjust the scaling. Just very small adjustments to fine tune alignment.
Also, to be able to simply copy a background image from one Level to another, so it's scaling and placement would be identical. Perhaps even better would be if we could add a background image and then specify in which Level(s) it should appear. Maybe even multiple images in the same level, suitably translucent to be able to see more than one. Obviously it would become meaningless with too many visible in one Level, but that would be up to the user.
Even just one image per Level would be ok though. So load up (and set scale and centre) any background image(s) you want to use and then for each Level you can pick from the list of already loaded images which one you want to display in that Level.
That would work for me. smile
