Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Cut glass » » » » Post: Re: Cut glass |
Print at Aug 31, 2026, 2:16:19 AM |
| Posted by okh at Aug 10, 2016, 11:06:46 AM |
Re: Cut glass Hei Lars, Seems many estate agents (here) tend to use these cut-off-wall presentations of properties. As Maz says, SH3D cannot cut the (window) models in half. A half window/door model is easy enough to make. Not sure how useful such models would be, though. If you want a similar cut-off presentation, you could: 1) set wall height to 150cm (or something), 2) use invisible windows that just cut the opening. (to make a door/window invisible, use the service hatch or some other door/window and set the frame material to invisible with Modify furniture > Modify materials). You will not see the frame or window-pane, but imho the effect is close enough. So close that there may not be a need for "half" windows in the collection. That said, the 3D exporter/viewer will allow you a more detailed and accurate view online, for instance thread 6956 and the 3D view (using the Exported homes manager). Nevertheless, here is a very quick mock-up of a half-window (toggle invisibility/colour of elements - you still need to adjust wall height, though): SourceForge 3D models 399: Window cut half. ok PS - engelsken din er glimrende, den , men det er mulig å spørre på norsk også i forum for fremmespråklige ...![]() |
Current timezone is GMT Aug 31, 2026, 2:16:19 AM |
