Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Put on board 30 cm high walls » » » » Post: Re: Put on board 30 cm high walls |
Print at Oct 4, 2026, 12:20:00 AM |
| Posted by okh at Aug 22, 2016, 9:59:40 PM |
Re: Put on board 30 cm high walls Hi Markus, sorry, I read your German and English question, but I have a problem figuring out what your problem is. The walls are easy to make, just change them to 330 cm high. Then, you could make a new level 330cm above the first level and use a box (or several boxes) and add wood texture. But I suspect I may not have understood what you are trying to do... Some more information (in German or English) and it might give you more replies. ok |
Current timezone is GMT Oct 4, 2026, 12:20:00 AM |
