Print at Sep 28, 2026, 4:56:15 PM
Posted by Puybaret at Sep 12, 2016, 5:26:51 PM
Re: Installation doesn't work. Software doesn't start.
Really strange... This kind of problem may happen on other systems, but not on macOS sad
Would you be able to run Sweet Home 3D from a Terminal window to report here the messages it will say? Simply drag and drop Sweet Home 3D application in a Terminal window, type back space, copy-paste /Contents/MacOS/SweetHome3D and press enter.
You could try also the free version but it will require that you install Java 6 too.
