Print at Oct 8, 2026, 9:48:41 AM
Posted by okh at Sep 23, 2016, 4:48:46 PM
Re: How to make sunlight from outside shine through window?
The reason you get no immediate response may be that there could be several different reasons. If you share your model it might be easier to give you an answer. Off-the-cuff, however, if the windows are facing due west and the time is noon, the sunlight should run approximately parallel with the windows and it would be understandable that little sunlight entered through the windows. Maybe you could try an evening rendering or a Sunlight simulation ... ok
