Print at Oct 4, 2026, 10:48:45 AM
Posted by okh at Oct 17, 2016, 8:05:24 AM
Re: Length of a wall in the middle of a wall?
Assuming I understand... Walls are always determined from their middle point, so if you thicken a wall, it will grow in both directions.
  • You can set Preferences - New wall thickness before you double-click with the room tool to create walls. But that does not work if you want a room with different thickness walls.
  • What is easier, may be to adjust both thickness and position of each wall afterwards to fit the room. (In your ase, the left wall X values should be some -10 cm compared to the original value.)
