Walls not vertically but under 75 degrees
This topic has been viewed 5227 times and has 2 replies
HobbyBouwer
Country: Nederland
Post by HobbyBouwer »
Hello Sweet Home Users,
I look for possibilities to put walls under an angle, ie 75 degrees with horizontal. Walls will standard be drawn under a 90 degree angle. Is that possible????
Thanks HobbyBouwer NL
Country: Paris, France
Re: Walls not vertically but under 75 degrees
Post by Puybaret »
No, it's not possible, walls angle with the floor is always 90°. See this tip if needed.
Miker777
Country: UK
Post by Miker777 »
Hi HobbyBouwer
If you position the walls you require, add windows, doors etc, then export it, on importing you could tip it to 75 degrees. If you do not require doors or windows, then i would suggest using the shape generator, this would enable to create a rhombus, keeping top and bottom surfaces horizontal.
Hope this helps.
