heating, Water and air pipes
This topic has been viewed 10945 times and has 4 replies
ersteinmal
Post by ersteinmal »
Dear all.
Intro: I stoppend my searching at Sweet Home because the Drawing is very simple.
But, my aim was, to sign pipes into my hause.
Is there a Way?
Regards Carsten
Davvey
Re: heating, Water and air pipes
Post by Davvey »
Hi
Yes there is a way to do pipes.
I did it by making a small circular wall and then exporting it as a piece of furniture. Then re-importing this and scaling it. I also made a small rectangular set of walls and exported that as trunking.
Davvey
Post by Davvey »
Sorry forgot to say also made right angle bends in both tube and trunking by using sloping walls to make half of a bend then imported it twice to get 2 halves. Then set them up as right angle bend and exported the 2 together to make bend.
Country: France
Post by VeroniQ »
You can find some hot and cold tubes in the example 6 of the gallery
Post by dorin »
I use some furniture library for pipes or wire. This is the result:
