Print at Oct 1, 2026, 2:14:39 AM
Posted by FranzMontana at Oct 28, 2016, 9:13:00 AM
Video generation
Provided that I’m enthusiastic of the tool that I think is unique in terms of simplicity and functionalities, I have a question about video creation.
The feature, although complete, is quite basic and apparently doesn’t allow to review the full list of points. We can only delete or change the last one. This is quite annoying if you have a long sequence of points and you want to have a good quality video, without gaps or sudden changes in views.
The best solution would be to have the possibility of changing all points and replay the sequence as many times as needed to reach the desired result, maybe at low quality to speed up the process, and then to have the final video generation at the best quality.
I noticed that the sequence is maintained after the file closure, meaning that is stored somewhere in the file. Is it possible to change, extend or reduce this sequence, which should be just a table with few fields (x, y, height, and the three angles)?
