Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate Room » » » » Post: Re: Rotate Room |
Print at Sep 29, 2026, 10:07:24 AM |
| Posted by dorin at Oct 28, 2016, 1:27:16 PM |
Re: Rotate Room Here is mine content of plugins folder: - 2016 AdvancedEditing.sh3p - 15:25 AdvancedSettings_PhotoRendering-1.3.sh3p - 2014 CalculateWallsAria.sh3p - 2015 CopyAsNewFurniture-1.2.sh3p - 2010 CopyStyle.sh3p - 15:25 CreatePhotoWithRenderer-1.2.sh3p - 2013 DimensionLines.jar - 15:25 ExportToHTML5-1.1.sh3p - 2009 ExportToSH3F-1.0.sh3p - 2015 RenameFurniture-1.2.sh3p - 2015 RoomAreaSum.sh3p - 2015 RoomPerimeter.sh3p - 2009 RoomVolume.jar - 2009 RotateHome.sh3p - 2016 ShapeGenerator-1.1.sh3p - 2015 UtilityPlugin.sh3p Whit AdvancedEditing You will have under Menu Edit-> Rotate.. & other options active after You select something or All. Whit RotateHome You will have under Menu Plan->Rotate; That will rotate 90 deg entire plan even You don't select something. To verify if the plugin is installed go to Menu About->Library. You must have the .sh3p file not the content of zip archive of that. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 29, 2026, 10:07:24 AM |
