Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Door swing in plan » » » » Post: Re: Door swing in plan |
Print at Sep 26, 2026, 11:05:26 PM |
| Posted by okh at Nov 2, 2016, 9:49:29 AM |
Re: Door swing in plan By the way - in addition to the above - just for your info - here are the values I used (after testing yours) for a normal door with a doorframe of 10 cm The original values do work, and may be the way you want them, but they could be a bit confusing if someone else tried them on a similar door. So I changed doorOrWindowWallThickness# so the frame protrudes on both sides of the wall, and I moved the door swing to inside the doorframe. I also added a full cut-out to avoid an empty frame being filled: ...ok |
Current timezone is GMT Sep 26, 2026, 11:05:26 PM |
