Print at Oct 9, 2026, 5:08:12 PM
Posted by enkonyito at Nov 4, 2016, 12:59:50 AM
Re: Autumn colours
@Ceciliabr
As it turns out, enhancing the external brightness works perfectly with textured skies, in fact it works better than with non-textured skies.
For a sky with texture, the effect of the Enhance external brightness option depends on the used image.
Here are some images showing different versions of the photo plug-in.
Version 1.2 has an option to enhance the external brightness for a sky without texture.
Option disabled (default)
Option enabled
Santbose,
As said Mazoola, Sunflow uses different types of light for a sky without texture (SunSkyLight) and a sky with texture (ImageBasedLight).
Although they have a parameter that seems common, rendering for a sky with texture depends on the image used (example: blue sky or cloudy sky).
Option disabled
Option enabled
EnkoNyito
