Print at Oct 10, 2026, 5:34:11 AM
Posted by Miker777 at Nov 14, 2016, 9:11:50 PM
Re: Loft
Hi emonchan, welcome to the forum.
If the porch/veranda you wish to create is on the ground floor then simply click on the "create room" icon on the tool bar, then create the room freehand, when you modify the "room" bare in mind the check boxs for ceilings etc. Also worth remembering is that with rooms created on the ground level the floor has no depth, i use rooms created on the upper floors, which do have depth to export and import for making objects like cabinets plinths, ceilings with depth, to hide light fittings, flat roofs etc
