Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with importing an specific OBJ file » » » » Post: Re: Problem with importing an specific OBJ file |
Print at Oct 6, 2026, 1:30:13 AM |
| Posted by Puybaret at Dec 6, 2016, 12:35:24 PM |
Re: Problem with importing an specific OBJ file I tried the files your sent to me, and FBX Converter seems to have a bug because the OBJ file contains a few numbers suffixed by #IND00 or #QNAN0, like 1.#IND00. If you remove all these suffixes (with a simple text editor), you'll be able to import the OBJ file. The imported file will be all gray, but this is another issue I can't help you about, since the MTL file that should contain colors and textures description is empty! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 1:30:13 AM |
