Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate object? » » » » Post: Re: Rotate object? |
Print at Sep 25, 2026, 9:25:54 AM |
| Posted by Puybaret at Dec 13, 2016, 7:06:52 PM |
Re: Rotate object? I guess you meant "around an horizontal axis". There's no direct way to do that yet, but you can circumvent this issue with this tip: - select the object you want to rotate - choose the 3D view > Export to OBJ format menu item, choose a file and when prompted select the option Export selection - choose the Furniture > Import furniture menu item, select the exported file and at the second step of the Furniture import wizard, rotate the model like you want, possibly using the shift key for a degree by degree rotation. Finish the importation, et voilĂ ! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 9:25:54 AM |
